v6.73+dev0125 - January 25 2023
+ ARA: add action to return selected items to ARA edit pool
+ ARA: add action to select all media items that use the same ARA pool
+ ARA: add action to un-pool selected media items for ARA edits
+ ARA: edits will not be preserved (with a warning) when loading a project created with a new version of REAPER into an old version of REAPER
+ ARA: improve stability of ARA edits when editing media items (splits, copies, etc)
+ ARA: old projects will always load with edits unpooled, to preserve the old behavior
+ ARA: support edits both per-media source (pooled) and per-take (unpooled)
+ Actions: add action to select all media items that use the same media source file
+ Actions: improve description of glue items action to match menu [t=275171]
+ Freeze: when freezing to mono/stereo, preserve audio sidechain receives [t=275106]
+ Freeze: when freezing, preserve MIDI-only receives [t=275106]
+ MIDI list editor: fix mousewheel action bindings [t=275224]
+ Notation editor: improve zoom layout in page view
+ Recording: fix potential extra count-in measure being added with round-to-measure checked [t=274889]
+ Take implosion: allow items to be imploded into multiple overlapping items [t=153354]
+ Take implosion: improve slight-overlap detection logic
# ARA: revert pooled edit behavior of +dev0124b
# Media item lanes: fix edits to unsynced comp areas affecting the comping lane [p=2639511]
# Media item lanes: fix re-syncing comp areas [p=2639510]
