REAPER v6.73+dev0126
v6.73+dev0126 - January 26 2023
+ ARA: list analyzed media files and pooled/unpooled count in FX + menu
+ ARA: retain audio edits when cut/pasting media items, and other cases where the plugin is not aware of an edited media item for a short time
+ Actions: add during/while as default synonyms
+ Actions: by default, T and shift-T will switch the comp area under the mouse up or down if there is one, otherwise will switch the active take of selected items
+ Lyrics.lua: support UTF-8 text editing
+ Media item lanes: add action/mouse modifier to create new comp area from mouse to next area or end of media
+ Media item lanes: add comp area double-click mouse modifier context
+ Media item lanes: support razor editing comp areas
# ARA: fix possible crash when deleting media items
# Media item lanes: improve re-syncing comp areas when media items are moved away and then moved back
