v6.73+dev0129 - January 29 2023
* Includes feature branch: text/control alignment improvements
+ Appearance: improve many small text/control alignment issues
+ FX: add menu item to cut FX including automation
+ Media item lanes: add comp area mouse modifier to create razor edit and move media items
+ Media item lanes: add preference to apply default crossfade to new comp areas
+ Project load: always show details of unrecognized project tokens
# Media item lanes: display razor edit button to create comp area only if razor edit does not contain a comp area
# Media item lanes: fix comp areas de-syncing after razor edit duplicate action [p=2640234]
# Media item lanes: fix displaying lane buttons for later tracks when one track is displaying track icon, lane buttons, and group indicators [p=2640289]
# Media item lanes: if both source and comp items are selected, comp areas move with media items
# Media item lanes: media items in the comping lane will remain in sync as long as the part of the item within the comp area does not change (it can be extended longer without un-syncing)
# Media item lanes: remove crossfade between comp areas when the same source lane is used
# Media item lanes: trim comp areas on other lanes after razor edit [p=2640319]
# Recording: fix aligning takes when recording to multiple tracks at once [p=2641133]
