v6.75+dev0204 - February 4 2023
* Includes feature branch: improved mousewheel and gesture accuracy
* Includes feature branch: text/control alignment improvements
+ IDEs: improve shift+click selection logic [t=275575]
+ Media item lanes: add action to implode fixed lanes to takes
+ ReaScript: gfx_getchar() fix for Ctrl+A-Z on macOS [t=275451]
# Media item lanes: action to explode takes to fixed lane affects selected tracks rather than selected media items
# Media item lanes: ensure playback is consistent with lane play state [p=2643369]
# Media item lanes: fix adding comp area within another comp area in certain situations [p=2643340]
# Media item lanes: fix copying comp areas via razor edit
# Media item lanes: fix mouse hit testing for lane buttons [p=2643454]
# Media item lanes: fix removing unused lanes in certain situations [p=2643349]
# Media item lanes: fix undo when comp area edit removes media items [p=2643350]
# Media item lanes: improve some behaviors when moving media items with comp areas [?p=2643368]
# Media item lanes: re-sync comp areas after copying media to project directory or replacing source media for items
# Media item lanes: update comping lane during edit when switching between media items that use the same source media but with different parameters (like item pitch) [p=2643439]
# Toolbar animations: now configured per-item in toolbar editor
# Toolbars: add option to not use animated armed button indicator
