v6.75+dev0208 - February 8 2023
* Includes feature branch: resizable render progress/statistics window
* Includes feature branch: improved mousewheel and gesture accuracy
* Includes feature branch: text/control alignment improvements
+ Automation: improve behavior recording into automation items
+ Automation: improve behavior when recording and looping
+ MIDI: do not chase (unsupported) NRPN when seeking
+ MIDI: when splitting MIDI items, add preference to disable CC/PC chasing
+ Media item lanes: add preference in comp area mouse modifiers to create a new comp area when dragging in any source lane (experimental)
+ Media item lanes: when drawing comp area in comping lane, if not within an existing comp area, use the following lane as the source lane
+ Media item properties: improve tab order, tweak alignment
+ Mouse modifiers: allow targeting razor edit areas and comp areas when arrange view override mouse modifiers are active
+ Render: support resizing render progress window wider, increasing peaks display size
+ Transport: improve time readout/status readout cross-platform alignment (updates default theme)
# Media item lanes: add mouse modifier to extend comp area to next comp area or end of media
# Media item lanes: fix action to implode fixed lane track to takes affecting unselected tracks [p=2644712]
# Media item lanes: fix comp area going out of sync when moved to an empty lane
# Media item lanes: improve action to implode fixed lanes to takes
# Media item lanes: improve behavior of action to implode takes to fixed lanes when items are crossfaded
# Media item lanes: when deleting unsynced comp area, don’t delete media items that were formerly associated with it
# Media item lanes: when finishing razor edit, trim existing comp areas only if the razor edit contains comp areas
# Prettification: improve media playback offset control alignment
