v6.75+dev0210 - February 10 2023
* Includes feature branch: resizable render progress/statistics window
* Includes feature branch: improved mousewheel and gesture accuracy
* Includes feature branch: text/control alignment improvements
+ Automation items: add preference to record to existing non-selected AIs
+ Automation items: avoid recording to underlying envelope behind existing AIs
+ Automation items: simplify description of ‘always record to automation items’ option
+ Automation items: when using trim-behind to split automation items, obey pool-on-split setting [p=2645486]
+ MIDI: global option to not chase MIDI note-ons also prevents chasing of MIDI CC/PC/pitch [t=206865]
+ Render: automatically resize filename column when resizing window
+ Render: render progress dialog remembers its size
+ WALTER: create custom controls by using “custom tcp.custom.xyz [label] [action ID] [accessibility description]” in layouts
+ WALTER: custom controls are text fields, support .font, .color, .margin
# Media item lanes: allow editing media within editable comp area when preference set to create comp areas in any source lane [p=2645469]
# Media item lanes: fix incorrect behavior when multiple tracks exist with identical comp areas [p=2645508]
# Media item lanes: fix re-syncing comp areas after moving and then moving back
# Media item lanes: improve behavior when recording in MIDI overdub mode
# Media item lanes: mouse modifier to edit comp area shared edges separately only applies when editing edges, moving areas never attaches to adjacent areas
# Media item lanes: prevent initiating comping on a track with no media items
