v6.77+dev0302 - March 2 2023
+ Accessibility: improve description of render postprocessing (normalize/limit/fade)
+ Automation: avoid cut/paste of track envelopes to contexts that do not support it
+ Automation: prevent hidden envelopes when moving FX to contexts that do not support it
+ FX Containers: allow feedback of a configurable number of high channels
+ FX Containers: support sub-chains of FX with configurable input/output/processing channel sizes, configurable parameter lists
+ FX Containers: use parent modulation/automation as baseline for any container-local modulation
+ MIDI editor: fix unmaximized window position saving on Linux/macOS
+ MIDI editor: screensets support maximized window state
+ MIDI editor: when restoring screensets, obey preference for opening all project or all track MIDI
+ MIDI: auto-name new MIDI items similarly to new audio media items, without "untitled MIDI item"
+ Media item lanes: add action and mouse modifier to copy unsynced comp areas to new lane and re-comp
+ Media item lanes: creating a comp area from a razor edit in an existing comp lane will instead copy the comped area to a new source lane [p=2653907]
+ Parameter modulation: allow for non take/track FX
+ Video: option to show background projects video if current project lacks video [t=273317]
# Media item lanes: default comp area left-drag mouse modifier allows horizontal move only
# Media item lanes: do not display razor edit button to create comp area when in comping lane
# Media item lanes: fix syncing take envelope edits within comp area
# Media item lanes: handle 2nd rapid modifier key click on lane button as a 2nd click rather than double-click
# Media item lanes: internal changes to mouse hit testing
# Media item lanes: move edit cursor on mouseup when comping
# Media item lanes: overlap and crossfade media items when splitting at comp area edges
# Media item lanes: reset lane names, last used comp lane when deleting all items from a track
# Media item lanes: simplify fade/crossfade handling
# Media item lanes: un-sync comp areas if media items change due to razor edit
# Media item lanes: when automatically comping new recording, only fit the comp area to time selection if the new recording fills the time selection
