REAPER v6.31rc1
v6.31rc1 - July 5 2021
+ JSFX: comment out slider_automate for the JSFX loudness meter output parameters, because it can cause those parameters to always be the last touched FX parameter [p=2460020]
+ Master VU: don’t show clip indicator in TCP meter when set to loudness, even if peaks clip
+ Normalization: use 64-bit intermediate file when rendering to normalized 32-bit PCM
+ ReaScript: fix SetEnvelopePointEx when used with automation items [p=2459830]
+ ReaTune: improve readout text on Windows [p=2459803]
+ Render: always run dry-run render actions at full speed regardless of other render preferences [p=2459647]
+ Render: fix embedding project markers/regions as cues [t=255268]
+ Render: make it extra super duper clear that no output file is created during dry run render
+ VST3: fix bridged UI support for some plug-ins [p=2459517]
+ VST3: fix issues that could cause stale reaper_host processes to stick around after removing plug-ins
# VST3: fix possible bridging over-release of objects [p=2459810]
# VST3: re-fix possible bridging over-release of objects [p=2459810]
