REAPER v6.79+dev0508
v6.79+dev0508 - May 8 2023
* Includes feature branch: run ReaScripts in REAPER (new instance or already-running instance) from the command line
+ Automation items: support toggling automation items following project default behavior without changing other settings [t=278999]
+ CLAP: do not apply plugin latency to MIDI events if the plugin produces MIDI output [t=278898]
+ MIDI: fix potential skipped or doubled MIDI notes when splitting by channel [t=278852]
+ Media item lanes: add action to delete lane under mouse
+ Media item lanes: add per-track setting to automatically create comp areas for new recording while comping
+ Media items: when option enabled to offset overlapping media items vertically, arrange media items that start at the exact same time in the order they were created [t=279000]
+ VST: do not apply PDC to MIDI if the plugin generates MIDI events, even if the plugin does not process MIDI input
# FX: properly handle enumerated parameters that do not have zero as the minumum value
# Grouping: propagate item and track groups to one another
