v6.32rc1 - July 8 2021
+ Batch converter: inform FX if channel count is higher than 4 [t=255033]
+ Envelopes: fix FX automation envelope defaults when moving media items [t=253431]
+ JSFX: add a parameter to control whether the JSFX loudness meter outputs loudness values as automation
+ JSFX: add internal meter update rate parameter to loudness meter
+ JSFX: fix stereo super8 export issues [t=255367]
+ Master VU: when master is set to mono, display identical RMS stereo loudness on the right meter channel [p=2460681]
+ Render: disregard setting to save copy of project before rendering when dry-run rendering
+ Wildcards: improve help for $marker(name) and $region(name) wildcards
+ Windows: fix VST3 loading from paths with UTF-8 characters (6.30 regression) [p=2461031]
# Render: make sure the correct sample rate is used for dry run render actions
