v6.79+dev0522 - May 22 2023
* Includes feature branch: run ReaScripts in REAPER (new instance or already-running instance) from the command line
+ CLAP: add clap_get_reaper_context() API
+ JSFX/ReaScript: support EEL2 preprocessor include()
+ LV2: non-automatable patch parameter support including atom:Path filename selection [t=252480]
+ MP3: fix possible incorrect initial latency when decoding
+ MP3: make peaks display at end of file consistent with other types
+ Regions: add action to select/unselect all regions for rendering
+ Video: default to OpenGL for video output
+ Video: fix typo in blitter feedback preset
+ Video: improve keyboard navigation of presets
+ Video: support project setting for YUV preview/conversion gamut: BT.601 (previous versions), BT.709, BT.2020
# FX: support flushing buffers on bypass for JSFX
# FX: support flushing buffers on bypass for lv2 plugins
# Media item lanes: make various behaviors consistent when inserting a lane
# Video: fix copying audio settings to video sources via video source properties dialog
# Video: fix persistence of audio peaks resolution setting
# Video: support UTF-8 localization in video source properties dialog
