REAPER v6.32+dev0710
v6.32+dev0710 - July 10 2021
+ JSFX: prevent reentrancy of @gfx code when TCP embedded and adding media on Windows [t=255367]
+ Render: display file length and channel count (if mixed) to HTML render statistics report
+ Render: fix dither/noise shaping when rendering stems [t=255450]
+ Render: fix normalizing stems to common gain based on master normalization when rendering multiple regions
+ Render: re-fix render peaks display [p=2461827]
+ Render: support normalizing stems to common gain based on normalizing master, even if not rendering master mix
+ Render: when rendering multiple files, display as much path as needed to disambiguate files
# Master VU: support UTF-8 localization in all master VU settings dropdowns
# Render: right-justify filename display in file dialog if it’s too long to display all of it
