v6.32+dev0712 - July 12 2021
+ Dockers: fix FX chain docker restoration when loading projects (requires re-save of existing projects)
+ FX: allow pin mapper dialog to be very large when first opened if the track has many channels
+ FX: remove global option for plugin bridging, bridging options should be controlled per-plugin via FX browser
+ JSFX: ensure IDE is not completely offscreen when showing [t=255478]
+ Media item properties: improve sizing behavior with scrollbar visible
+ ReaScript: add GetSetMediaTrackInfo support for getting/setting track VU mode
+ Render: don’t display file extension during dry-run render
+ Theme: fix customizing master track VU readout text color in TCP [t=255486]
+ Track VU: support metering RMS, LUFS-M, or LUFS-S
+ Wildcards: fix $namenumber wildcard [t=255473]
# Render: fix format output display when normalizing stems to master but not rendering master
# Render: handle UTF-8 correctly when right-justifying filenames in stats
