v6.80+dev0612 - June 12 2023
+ Actions list: detect and support multi-word synonyms [t=278803]
+ Actions window: allow removing shortcut by hitting delete while shortcut list focused
+ MIDI: allow entering text events of any length [t=273491]
+ MIDI: automatically quantize media content start position to PPQ when quantizing MIDI [t=279531]
+ Multiple instance checking: automatically support running multiple instances when using different app/ini paths on macOS/Linux
+ WALTER: add trans.status.color configuration
# Actions list: internal synonym support overhaul, may change various corner cases
# FX: improve precision of sample times reported to JSFX, CLAP, AU
# Media item take markers: fix mouse hit testing multiple markers within the same media item
# Tempo/time signature: improve behavior of action to insert time when tempo envelope timebase is set to beats
# Video: avoid potential empty frames when encoding video and using very-slow-to-seek sources [t=279676]
# WALTER: allow custom for master.tcp/master.mcp contexts
