REAPER v6.81+dev0717
v6.81+dev0717 - July 17 2023
+ Batch converter: support preserving metadata when converting from media item [t=260528]
+ Media item lanes: remove support for unsynced comp areas [p=2693324]
+ Take: fix various behaviors when reversing take via action [t=280742]
+ WALTER: if mcp.extmixer.mode is set to [-1], use mcp.extmixer.position as margin offsets
+ macOS: fix various retina-related display glitches (e.g. zoomed-in item labels)
# Development theme: master mcp hidpi
# Theme: mcp_recarm_norec fallback to track_recarm_norec before mcp_recarm_on, etc
# macOS: improve Metal display scheduling
