v6.81+dev0728 - July 28 2023
+ Project bay: display bridged status in performance column, allow filtering to match this status
+ Project bay: when in FX tab, filtering searches preset, developer, type
+ Project bay: when matching FX, allow words to be matched from different columns
# Media item lanes: fix mouse modifier to move/copy media items and comp areas together
# Media item lanes: fix preserving media items outside of comp areas during comp area edits
# Media item lanes: fix small items potentially left behind after comp area edits
# Media item lanes: improve razor editing behavior when comping
# Media item lanes: revert free-overlap behavior of comp areas from previous +dev build
# Media: remove unnecessary nul character in raw PCM media .rsrc.txt file [t=281217]
