v6.81+dev0731 - July 31 2023
+ Media items: improve interactions between auto-crossfade project setting and crossfade preferences when trimming content behind media item edits
+ ReaScript: allow gfx_showmenu() without gfx_init() on Windows [p=2697068]
+ ReaScript: support using full (unlocalized) action description in SetMouseModifier(). For example SetMouseModifier("MM_CTX_ITEM", 0, "1 m") and SetMouseModifier("Media item left drag", 0, "Move item") are equivalent
+ ReaScript: support using full (unlocalized) mouse modifier context description in GetMouseModifier() and SetMouseModifier(), for example GetMouseModifier("MM_CTX_ITEM", 0) and GetMouseModifier("Media item left drag", 0) are equivalent
# Actions: ensure that actions to toggle/enable/disable auto-crossfade on split work predictably [p=2696981]
# Media item channel selection: support choosing mono or stereo input from 128 channels
# Media item lanes: fix mouse modifier/action to delete comp area but not media items
# Media item lanes: hopefully improve fadein/fadeout interaction between source lanes and comp lane
# Media item lanes: improve behavior when razor editing [p=2696853]
# Media item lanes: revert preserving unsynced media items in the comp lane during edits
# Preferences: fix localization for Preferences/Item fade defaults page
