v7.0pre4 - August 6 2023
+ Drag/drop: support drag/drop onto track spacer (if preference enabled to insert track on drag/drop, insert track, otherwise add media to previous track)
+ Envelopes: add preference pane "Envelope Colors" to allow defining custom envelope colors based on envelope name
+ Preferences: disable automatic fadein/fadeout for imported media by default for new users
+ r8brain-free: update to 6.3
# Drag/drop: internal changes
# Media item lanes: fix potential display glitch when mouse-dragging comp areas and media items together to add-lane area [p=2698771]
# Meters: minor display tweaks for gain reduction
# Preferences: ensure all users start with automatic fade-in/fade-out disabled for imported media items in v7
# ReaScript: make Lua 5.4 math.randomseed() more permissive to be compatible with lua 5.3 code
# Vertical zoom: improve behavior when maximum vertical scroll is greater than 100%
# Zoom: improve behavior when vertical zoom preference is track at center of view
