v7.0+pre5 - August 8 2023
+ Actions: add action to show/hide children of selected folder tracks
+ JSFX: add ext_gr_meter extension (set to non-positive values in @init and @block to report gain reduction)
+ Media item lanes: add mouse modifiers to move comp area and adjacent comp area edges [p=2699384]
+ Mouse modifiers: add menu action to export current modifiers for the current context as a script [p=2699692]
+ Mouse modifiers: support user-supplied custom toolbar button tooltip for arrange view override contexts
+ Mouse: envelope control panel respects preference to ignore mousewheel on all faders
+ Mouse: respect preference to reverse mousewheel when scrolling TCP [p=2699501]
+ Preferences: move track meter appearance settings to a separate page
+ Sliders: respond to mouse click anywhere in the slider window, not just within the width of the thumb image [p=2699292]
+ Tracks: add actions to toggle track zoom height to default; cycle track zoom height between minimum, default, and maximum
+ Zoom: fix action to toggle tracks to maximum zoom when maximum zoom preference is set to less than 100% [t=278952]
# Automation items: fix bug when drawing automation item right to left [t=279327]
# Envelopes: adding color filter prompts for filter string immediately
# GR metering: synchronize with track metering
# Meters: display gain reduction matched to track meters, with configurable scaling factor
# Meters: do not apply ballistics/decay to gain reduction metering (plugin extension docs say to display the value as-is)
# Meters: fix gain reduction display on master track
# Meters: prevent gate plugins from reporting infinite GR constantly [p=2699025]
# Preferences: set 'trim behind media edits' crossfade preference to 'respect toolbar auto-crossfade button' by default
# ReaScript: after running SetMouseModifier function, refresh mouse modifier preferences page if it is open
