v7.0pre6 - August 11 2023
+ Actions: consistently refer to collapsed folders as 'collapsed' rather than 'compacted'
+ Crossfades: limit overlap and crossfade when splitting at time selection or razor edit [p=2699919]
+ FX: fix issues when per-FX PDC mode is combined with auto-bypass [p=2700214]
+ Media item lanes; draw faint peaks to indicate items in collapsed lanes
+ Media items: store fade-in/fade-out length with greater precision in project files
+ Mouse modifiers: support existing custom actions or scripts that use deprecated "set default mouse modifier for context" actions (actions no longer appear in the actions list, do not support menu/toolbar feedback, and will not support new mouse modifiers)
+ Paste: when pasting into FIPM or fixed lane track, target the y-position or lane of the last mouse click (experimental)
+ Tracks: add preference to not display tracks in a folder when the folder is fully collapsed
# Fades: fix crossfade behavior with recorded items in some scenarios [p=2699919]
# Media item lanes: ensure that previous comp areas are preserved when creating new comp lane [p=2700115]
# Media item lanes: fix mouse editing comp area left edge at project start [p=2699832]
# Media item lanes: fix some unexpected behaviors when loading projects or after undo
# Media item lanes: improve some crossfade behaviors when editing comp areas
# Media item lanes: improve use of space when re-comping multiple media items
# Media item lanes: prevent mouse changing lanes when lane buttons are not displayed [p=2699834]
# Media item lanes: simplify lane color menu
# Media item lanes: update item color during comping [p=2699846]
# Media item lanes: when automatically creating comp areas, prioritize media items in higher lanes
