REAPER v7.0pre8
v7.0pre8 - August 15 2023
+ Media item lanes: add per-track setting to control whether recording into a new lane plays only that lane or leaves previously playing lanes unchanged
+ Metadata: snap BPM auto-detected from filename to samplerate
+ Peaks: existing preference to scale (or not scale) peaks by pre-fx track envelopes also applies to per-take envelopes
+ Preferences: add preference for envelope lane height as a percentage of track height, when zooming vertically (default 50%)
+ Preferences: move zoom/scroll preferences to dedicated page
# Media item lanes: add "horizontally" versions of mouse modifiers to move comp areas and adjacent area edges
# Media item lanes: add mouse modifiers to move comp areas and media items while attaching to adjacent comp area edges
# Media item lanes: improve behavior when using mouse modifier to move comp areas and adjacent edges [p=2701736]
# Media item lanes: remove hidden peaks display for collapsed fixed lanes
# Media item lanes: revert project setting for new recording to play back by default
# Tracks: when vertical zoom center preference is the last selected track, center the track (not including envelope lanes) in the center of the arrange view
# Tracks: when vertical zoom center preference is the top of the view, hold the relative track position (including envelope lanes) constant at the top of the arrange view
# Tracks: when vertical zoom center preference is the track at view center, hold the relative track position (including envelope lanes) constant at the center of the arrange view
# Tracks: when vertical zoom center preference is the track under the mouse, hold the relative track position (including envelope lanes) constant at the mouse position
不知道正式版什么时候出来呢
