v7.0pre13 - August 28 2023
+ Marker/region manager: support importing multiple markers/regions with the same time position
+ Media items: do not autoscroll when adjusting media item contents [p=2706019]
+ Preferences: obey actions window synonyms option when searching
+ Recent projects: if holding alt/opt when opening project, load with FX offline
+ Track templates: fix incorrect loading of certain track template content [t=281970]
+ Zoom: support vertical scroll step as percentage of track height or percentage of arrange view height
# Media item lanes: add preference to Loop/Lane Recording page to add the entire recording after time selection auto-punch recording into a fixed lane track
# Media item lanes: button/action to show only one lane affects all edit-grouped tracks [p=2706052]
# Media item lanes: default to small lanes instead of big lanes (lane size in previously saved projects will change)
# Media item lanes: improve behavior when editing comp area shared edges and one edge of the edited area crosses the other
# Media item lanes: improve behavior when editing comp areas attached to adjacent area edges
# Media item lanes: move preferences for which lanes play after new recording to Loop/Lane Recording preferences page
# RAW PCM sink: fix incorrect clamping of PCM samples very close to but not equal to 1.0
# RAW PCM source/sink: support 32-bit integer modes
# Raw PCM sink: support big endian FP
# Render: fix persistence of option to not write sidecar file when rendering raw PCM
# Toolbar: remove button to initiate comping from default toolbar (instead use mouse modifiers, double-click a lane button, or use the lane button context menu)
# Zoom: when zooming into a track that will fit onscreen at maximum zoom level, and not zooming into an envelope lane, ensure the whole track is onscreen
