REAPER v7.0pre16
v7.0pre16 - September 4 2023
+ License: display license valid-through version in About/Purchase window
+ MIDI editor: actions to grow MIDI notes will auto-extend the MIDI item according to preference
+ Metadata: support multi-line render metadata (right-click value cell to open multi-line editor) [t=282304]
+ Preferences: add preference in track defaults page for default fixed lane size (small or big)
+ Project metadata: do not commit metadata if user presses escape key while editing
+ Render: display message when saved render format is not available
+ Render: support forcing mono/stereo/multichannel render for master mix via region render matrix
+ Render: when loading project or render preset with a render format that is not available on the current machine, leave the render format dropdown blank
# Media item lanes: display indicator for fixed lane tracks when track height is too small for lane buttons
# Media item lanes: fix comp area syncing with different combinations of media start-in-source and playback rate
# Media item lanes: improve handling of comp areas when moving or copying project regions
# ReaScript: rename API function to UpdateItemLanes()
# WALTER: fix issues with minimum sizes and positioning of tcp.sendlist etc
# Zoom: when vertical zooming to mouse position and mouse is above the top track or below the bottom track, zoom to the top or bottom track [p=2707775]
