REAPER v7.0pre28
v7.0pre28 - September 21 2023
* Includes feature branch: support up to 32 main toolbars, 16 MIDI toolbars
* Includes feature branch: MIDI CC vertical zoom/scroll
+ Color theme: add theme color for fixed lane name text
+ Color theme: add theme images for fixed_lanes_small, fixed_lanes_big, fixed_lanes_one
+ MIDI editor: add actions to set pitchwheel semitone range, snap
+ MIDI editor: fix undo when editing left edge of parent item [t=282888]
+ Media item lanes: add action to move items down to next available lane, adding lanes as needed
+ Media item lanes: add setting to snap media items to media items in other lanes
+ Media item lanes: add snap setting to snap fixed lane comp areas to media items in the same lane (enabled by default)
+ Render: respect preference to close render window when done, even when normalizing (but leave the window open when dry run rendering regardless of the preference)
+ Track grouping: add option (enabled by default) for track media item grouping to affect only items that start and end at the same time (rather than any enclosed media item)
+ VST: support VST3 preset paths on Linux
+ macOS: fix retina drawing errors introduced in 6.82
# Media item lanes: action to move item down one lane will convert non-fixed-lane-track to fixed lanes if needed
# Media item lanes: update lane button display when lane is small
# Theme updates
