REAPER v7.0rc2
v7.0rc2 - September 25 2023
* Includes feature branch: support up to 32 main toolbars, 16 MIDI toolbars
* Includes feature branch: MIDI CC vertical zoom/scroll
+ API: preserve FXID when cutting/pasting FX, saving/loading RfxChain
+ MIDI editor: improve pitch lane horizontal guideline appearance when pitchwheel range is set
+ MIDI: option to apply CC curve shape to recorded events does not override preference to prevent CC curve shape in bank, LSB, sustain lanes
+ Media item lanes: do not crossfade comp areas on tracks with only MIDI items
+ ReaScript: GetTrackFromPoint() also returns the fixed lane under the mouse, if applicable
+ ReaScript: add support for GetSetMediaTrackInfo_Value('I_NUMFIXEDLANES'), GetSetMediaItemInfo_Value('I_FIXEDLANE')
+ Track reordering: improve drag and drop behavior when dragging a track in-place
+ Tracks: when inserting tracks after a folder whose children are all hidden, insert after children
# Dynamic split: fix behavior when splitting grouped tracks with trailing pad [p=2714515]
# FX: fix loading of FXID from projects/templates/etc
# Media item lanes: fix behavior of actions to split item under mouse when lanes are collapsed
# Media item lanes: when displaying lane spinner control, light the center button if any lane is playing
# Meters: auto-increase peak hold width/height when interlacing is enabled [p=2714454]
# Notation view: revert displaying notes as clustered regardless of voice or note length (experimental commit from August 2022)
# Theme: change default minimum mixer size, use meter bridge mode if multi-row is enabled and fx inserts/parameters are disabled
# Track reordering: show folder cursor when dragging to a folder track that has no visible children
