REAPER v7.0rc4
v7.0rc4 - September 28 2023
* Includes feature branch: support up to 32 main toolbars, 16 MIDI toolbars
* Includes feature branch: MIDI CC vertical zoom/scroll
+ Actions: improve action to show/hide children of selected tracks [p=2715860]
+ MIDI editor: fix deselecting CC events when clicking lane outside envelope, when preference enabled to draw/edit immediately on mouse click
+ ReaDelay: improve behavior of musical length slider
+ ReaScript: faster API validation for takes and envelopes
# Comp areas: improve fadeout snap behavior when areas are crossfaded
# Comp areas: improve snap/crossfade behavior
# Comping: collect comp area changes into undo point after razor edit
# Defaults: fixed lane tracks have big lanes by default (if you have changed this preference, you'll need to change it again)
# FX: fix duplicate FXID created by dragdrop copy of FX
# FX: improve behavior if a plug-in is named 'Container' or 'Video processor' [p=2715953]
# Media item lanes: add action to delete all comp areas but keep media
# Media item lanes: don't update comp areas when moving/copying media items on source lanes and comping lane at the same time [p=2715821]
# Media item lanes: improve mouse precision when creating comp areas
# Media item lanes: when deleting the only playing lane, set the previous lane playing
# Menus: fix customized fixed lane controls context menu not persisting
# Preferences: support changing 'allow editing source media while comping' and 'automatically comp new recording' as track defaults
# ReaComp: fix resetting ratio parameter on double-click
# ReaDelay: improve defaults
# ReaVerbate: improve defaults
# TCP/MCP list views: fix layout bug relating to multi-column [p=2715737]
# macOS: clear TCP resize indicator when mouse moves below last track
