v7.0rc7 - October 4 2023
* Includes feature branch: support up to 32 main toolbars, 16 MIDI toolbars
* Includes feature branch: MIDI CC vertical zoom/scroll
+ Drag and drop: fix potential crash [t=283153]
+ Media item lanes: add mouse modifiers to edit comp areas stopping at media item edges
+ ReaScript: add GetTouchedOrFocusedFX(), supports container addressing, deprecates GetFocusedFX2 and GetLastTouchedFX
+ ReaScript: fix gfx.drawstr() on multiline content drawing with negative Y offset [t=282702]
+ Transport: add support for Measures.Beats as secondary time unit [t=283214]
# Embedded FX: reduce memory use when hiding embedded FX from TCP view
# FX: fix last focused FX behavior for containers
# MIDI editor: fix inserting CC event on mouse down with certain customized mouse modifiers [p=2717465]
# Media item lanes: action to play only next lane counts from the first playing lane (rather than the last playing lane) if multiple lanes are already playing
# Media item lanes: consolidate undo point for comp area syncing for various actions [p=2717447]
# Mixer: fix drawing bug with FX which no longer support embedded UIs [p=2717495]
# ReaScript: fix setting raw PCM render configuration via API
# Theme: Mixer folder balancing by varying track name height
# Theme: User chosen background colour also affects track index area background
# Themes: support manually overriding fonts per-OS in .ReaperTheme file by using _mac/_lin/_win suffix for font names
