REAPER v7.001+dev1017
v7.001+dev1017 - October 17 2023
+ Comp areas: improve behavior when copying regions that contain comp areas
+ FX containers: do not auto-migrate modulation to parent when pasting/moving FX [t=283626]
+ JSFX: hide loudness meter maximum value display when meter is tiny [t=283539]
+ JSFX: improve watch window filtering, allowing both general filter syntax plus refs=1 or value>1 etc
+ Parameter modulation: fix parameter linking when copying to new tracks [t=282137]
+ ReaScript: fix setting of FX param.X.plink.effect
+ ReaScript: optimize CountSelectedMediaItems/GetSelectedMediaItem
+ Super8: improve performance when starting recording on multiple channels simultaneously
+ Theme: fix squashed record arm buttons
+ Track panels: correct multichannel input label/tooltip [t=283594]
+ Track templates: warn if FX are offline on import [t=257672]
