v6.35 - August 25 2021
+ Action list: optionally match synonyms of common words when searching for action names ("display" matches "show", etc)
+ Action list: pull list of synonyms from langpack actionlist_synonyms section
+ Actions: use correct tempo when running action to insert tempo marker without opening tempo marker editor, and time signature is not x/4 [t=256772]
+ Automation: obey grid/snap settings when using freehand draw
+ Automation: restore 6.33 behavior when adding a single point via freehand draw [t=256406]
+ FX: add pin mapping dialog actions to clear or reset mappings
+ FX: correct floating window titles in various cases [t=256595]
+ General: fix logical sorting issues in region manager and elsewhere [t=256759]
+ JSFX: support linked stereo channels in channel mapper user mix mode
+ Language packs: improve behavior with dialog scaling and existing langpacks in render window [t=256670]
+ Linux: fix issues with non-US numeric locales and plug-ins that reset locale
+ Linux: improve save-as window default extension handling [t=256824]
+ Linux: show multi-instance options in preferences [t=256744]
+ Marquee zoom: allow tracks to be sized smaller in order to fit on screen [t=256339]
+ Master VU: fix LUFS-S meter text readout when set to display current level rather than max or LRA [p=2471528]
+ Media items: support entering numeric values for take volume/pan in properties window
+ Media items: reset snap offset if right edge resized less than offset [t=256571]
+ Metadata: fix embedding CART intro/segue markers that occur at the very start of the rendered file
+ Metadata: support embedding project markers/cues as XMP when rendering (for Premiere, After Effects, etc)
+ Metadata: fix invalid memory access from unknown ETCO type in ID3v2 parsing
+ MIDI: encode gradual tempo changes on export as MIDI text messages that REAPER can interpret when reimporting (other applications will ignore these messages and import stepwise tempo changes)
+ Performance: fix potential excessive UI CPU use/hang when closing project when edit cursor is offscreen [t=256285]
+ Project bay: fix dragging automation items into project [p=2473112]
+ Project bay: fix memory leak when running action to restore source media
+ Project bay: increase project length if needed when dragging media items from project bay [t=254865]
+ Razor edits: fix editing envelope point that occurs at the start of an automation item [p=2471931]
+ Razor edits: support stretch markers in media items that contain empty take lanes, if there is at least one audio take [t=256443]
+ ReaComp: fix legacy parameter reset when using factory default preset
+ ReaComp: hide deprecated parameters if they are not being used (accessible via compatability parameter in generic UI)
+ ReaScript: add GetSetMediaTrackInfo support for getting/setting track VU mode
+ ReaScript: add PCM_Source_BuildPeaks to allow scripts to build peaks for PCM_sources
+ ReaScript: prevent crash from incorrect use of PCM_Source_Destroy()
+ ReaSurround / ReaSurroundPan: allow plugin to support higher I/O channel count than the track or media item
+ ReaSurroundPan: label an elevated speaker in the center of the room as "overhead", other elevated speakers as "height"
+ ReaSurroundPan: when LFE channel is selected, allow changing input faders to gain, but disable the channel text edit box
+ Render: display up to 512 vu meters, limited to the screen height
+ Render: iterate for increased precision when normalizing to LUFS-I
+ Render: master and track meters display levels after sample rate conversion, if any [t=256570]
+ Render: more informative error message if target file cannot be created
+ Render: optimize loudness calculations
+ Render: separate render statistics header for clearer display when rendering many files
+ Render: support dithering primary and secondary render format to different bit depths [t=256483]
+ Render: support enabling LUFS-I/LUFS-M and LRA/LUFS-S statistics separately
+ Ripple editing: improve behavior of actions to duplicate items within razor edit or time selection [t=256114]
+ RS5k: improve default value for minimum velocity
+ Tempo markers: support tempo basis other than 1/4 note (affects displayed BPM number only, not metronome or tempo envelope display) [t=250880]
+ Theme: add meter_strip_h_rms image, consistently use loudness meter theme elements for tracks that are set to meter loudness
+ Tracks: support mono master/parent send, via single-channel entries in parent channels dropdown in track routing dialog
+ Track VU: add metering settings submenu to track context menu as well as track VU context menu
+ Track VU: support metering RMS, RMS stereo, LUFS-M, LUFS-S
+ VST3: fix incorrect handling of IContextMenuItem flags
+ Windows: avoid potential splash screen hang when caught in an invalidate/postmessage loop [t=256285]
