v7.06+dev1202 - December 2 2023
* Includes feature branch: preserve metadata when rendering media items
* Includes feature branch: envelope list window improvements
* Includes feature branch: video processors in containers
* Includes feature branch: large number of video items CPU use optimizations
* Includes feature branch: record armed tracks obeying 'do not run muted tracks' preference
* Includes feature branch: support non-SMPTE 7.1 channel order
* Includes feature branch: support copying comp area edits back to source lanes
* Includes feature branch: optionally limit media item edge edits to start/end of source media
+ API: allow plug-ins to register default-global hotkeys via gaccel_global or gaccel_globaltext
+ Envelope window: add combobox for filtering active envelopes, last touched FX parameters, etc
+ Envelope window: filter now supports matching Mod, Learn too
+ FX containers: intelligently manage parameter linking when moving/copying FX across containers
+ Lanes: add action to remove empty comp areas
+ Lanes: add selected-tracks versions of actions to delete comp areas, delete empty comp areas, delete comp areas including media
+ Lanes: fix behavior of action to select item under mouse when lanes are collapsed [t=285725]
+ Lanes: fix some edge cases where comp areas un-sync when edges barely overlap [p=2739194]
+ Tracks: when preference enabled to change track selection when clicking track controls, ignore modifier keys when processing track selection
# Envelope window: improve resize behavior in response to filtering
# FX containers: support remapping of container FX parameters when moving FX between sub-containers
