v6.36 - September 3 2021
+ Actions list: improve the naming of various selection related actions
+ Actions list: add deselect,unselect to list of action name synonyms
+ Actions list: match synonyms when next to various non-alphanumeric characters
+ API: allow plug-in audio hooks to read/modify incoming MIDI messages from the current block
+ API: add GetThingFromPoint() which can return WALTER elements
+ API: add read-only track property to read position of WALTER elements, e.g. P_UI_RECT:tcp.mute
+ Freeze: add option in preferences/rendering to generate muted silent items from muted source items [t=255812]
+ FX browser: add menu item to duplicate JSFX
+ FX browser: add option to always search all FX when using search field [t=256322]
+ Linux: safer plug-in X11 window destruction
+ macOS: improve default focus of various windows
+ MIDI: don't allow setting MIDI note-on velocity to zero in event properties dialog
+ Peaks: label slider "display zoom" in peaks settings window to match action names
+ Preferences: enable apply button when toggling 'allow space key to be used for navigation' setting [t=256970]
+ Render: automatically filter control characters from filenames on render targets [t=256971]
+ Tracks: option to disable track metering affects only selected tracks
+ Video: fix rendering at framerates lower than 1/video_cache_size [t=256901]
+ Video: update media item labels when loading user presets on a take-FX video processor [t=256861]
+ VST: improve VST3 handling of 0x90-encoded note-offs [t=256283]
+ VST: detect changes to window size on Linux bridged VST2
+ VST: fix UI idle processing for bridged VST2 on Linux
+ VST: prevent calling effEditClose twice on Windows and macOS bridged VST2 plug-ins [p=2474831]
