REAPER v7.11+dev0213
v7.11+dev0213 - February 13 2024
* Includes feature branch: Media Explorer time selection, channel selection improvements
+ Initialization: Warn on startup if configuration file cannot be written to (avoid unexpected behavior when running portable installation without write permission to directory, for example)
+ Lanes: handle corner case when auto-remove lane from two lane track with no media [p=2757796]
+ Notation: fix ties when note extends past the right edge of the screen in continuous view [t=288216]
+ ReaScript: add Lua usage example for SendMIDIMessageToHardware() [t=276925]
+ Toolbars: update customized toolbar buttons after actions to display various views of the routing/grouping/region matrix window [t=288273]
+ Transport: fix macOS retina drawing glitch with some themes [t=288253]
