v6.38rc1 - October 16 2021
+ JSFX: add options to Loudness Meter for writing automation inverted and selecting single output value
+ Media explorer: separate multichannel peaks display by one pixel
+ ReaComp/ReaGate: perform extra validation on multichannel mode configuration state
+ ReaEQ: fix UI update issues when loading presets on Windows
+ ReaEQ: update graph display when resizing and analysis is disabled [t=258420]
+ ReaScript: fix TakeFX_GetParamFromIdent [t=258477]
+ ReaScript: fix potential crash when hit testing over TCP mono button [t=258528]
+ ReaScript: hit test functions now detect master.tcp.mono etc
+ ReaVerb: fix incorrect processing on very sparse non-mono signals (e.g. click sources) [p=2488323]
+ ReaVerb: fix reverb generator crash with zero-width (6.37 regression) [t=258397]
+ ReaXcomp: fix UI update issues when loading presets on Windows
+ Render: localize "dry run" text
+ Theme: add mcp_fxembed scalar to WALTER [t=257691]
+ macOS: improve textfield behavior with certain key mappings in menu items [t=258450]
# ReaScript: update TrackFX_GetParamFromIdent documentation for delta parameter
