REAPER v7.16+dev0528
v7.16+dev0528 - May 28 2024
* Includes feature branch: RGB profile tweak
* Includes feature branch: improved UI for editing click pattern in metronome, time signature markers, and click source properties
* Includes feature branch: improvements to grid spacing and labeling with compound time signatures
* Includes feature branch: improved loudness peaks
* Includes feature branch: global preference to crossfade left, center, or right when splitting
* Includes feature branch: optionally display mouse position indicator line in arrange view
* Includes feature branch: changes to lane recording settings and behavior
* Includes feature branch: up-rank/down-rank takes and take markers
+ Click: support entering click volume directly in click source properties dialog
+ Import: properly handle user cancelling multiple media item import dialog [t=288431]
+ Metronome: internal changes
+ Metronome: support entering dB click volume directly
+ Preferences: create new General/Undo tab for undo-related settings
+ Render: support render setting to preserve source media sample rate if possible
+ Undo: add option in preferences to control whether MIDI event selection creates undo points
+ macOS: fix quirks with 'show last undo point in title bar' option
# Click: fix saving/restoring click pattern that contains triplets on secondary beat
# Metronome: support default compound click pattern for all x/8 other than 4/8
