REAPER v7.16+dev0606
v7.16+dev0606 - June 6 2024
* Includes feature branch: Default 7.0 theme adjuster inclusion
* Includes feature branch: up to 4 different click types/samples in metronome
* Includes feature branch: render setting to preserve source media sample rate if possible
* Includes feature branch: RGB profile tweak
* Includes feature branch: improved UI for editing click pattern in metronome, time signature markers, and click source properties
* Includes feature branch: improvements to grid spacing and labeling with compound time signatures
* Includes feature branch: improved loudness peaks
* Includes feature branch: global preference to crossfade left, center, or right when splitting
* Includes feature branch: optionally display mouse position indicator line in arrange view
* Includes feature branch: changes to lane recording settings and behavior
* Includes feature branch: up-rank/down-rank takes and take markers
+ Grid: automatically add a small amount of contrast to vertical grid shading colors, if the option to divide the arrange view vertically is enabled and the theme colors for odd/even track backgrounds are very similar
+ Linux: improve knob appearance when using dark mode libSwell.colortheme
+ Medi explorer: when displaying ruler/playback position/time selection in beats, use raw beat count rather than measures.beats (because there is no time signature context)
+ Media explorer: add option to display preview position and time selection in beats for audio files, using embedded or estimated tempo
+ Media explorer: do not display estimated tempo for file types that will ignore estimated tempo on import
+ Media explorer: move setting to display preview position in fractional vs whole seconds to Show menu (from Options menu)
+ Mouse: optionally display mouse position indicator at snapped position in addition to unsnapped position
+ Preferences: move ruler/grid settings into new tab under Appearance
+ Ruler: add preference to display all fractional beats as measure.beat.(x/y)
+ Theme: include Default 7.0 theme adjuster
# Metronome: fix loading click patterns from old projects
# Metronome: fix score editor's use of metronome for rhythm pattern
# Ruler: fix possible crash when ruler set to very small triplets
# Ruler: improve labeling of 1/8 note triplets
# Takes: action to delete all take markers in item affects all takes, not just the active take
