VSTBuzz has launched a new deal on Bute Limiter 2 by Signum Audio. With this offer, you can get the plugin for just €19, instead of the usual €69 (a whopping 72% discount)!
This is a limited-time deal that only lasts till November 4th, so get your hands on it before you miss out!
Bute Limiter 2 is described as a high-fidelity, ultra-transparent true peak brickwall limiter. This stereo version supports 2-channel configurations, but there’s also a Surround version with 10-channel support.
The interface looks sleek with a very modern design. There’s a lot of information on-screen here. But it’s still easy to navigate with the primary controls at the bottom – Pre-Gain, Threshold, Release, Curve, and Post Gain.
There are automatic modes for setting the Release and Max Target too. The Max Target feature is very handy because you can just set your desired limit, and the software will analyze your signal to achieve that in the most transparent way possible.
When it comes to limiting, Bute Limiter 2 offers five different release curves – Linear, Natural, Transparent, Pumping, and Smooth.
You can also choose between three different layouts – Resizable History View, Vertical Metering View, and a Horizontal Control View. So you place the plugin window wherever you want – a full monitor, or as a small toolbar at the top.
Plus, it keeps a history of the output readings along with in-depth analysis, so you can go back and see how your mix is evolving as you make changes. It’s a small but really neat feature!
It automatically syncs to your DAW’s transport, and there’s a warning system for Post Gain overshoots so you can fix any limiting issues immediately.
Here’s a quick overview of the plugin from its developer:
Bute Limiter 2 is compatible with is available in 64-bit VST, AU, and AAX plugin formats. It will run on both Windows (8.1 or higher) and macOS (10.9 or higher).
And here’s an interesting fact: Signum Audio was founded by two ex-Rockstar North audio engineers. So if you’re a GTA 5 fan like me, you’ve probably heard their work before!
At just about $21, this is probably one of the sweetest plugin deals you can get right now. So if you were looking for a new transparent limiter to try out, don’t pass it up!
A free demo is also available if you want to evaluate the software before purchasing. The plugin currently has a 9.67/10 score at VSTBuzz.
Bute Limiter 2 (€19 @ VSTBuzz until November 4th)
资讯出处:Get 72% OFF Signum Audio’s Bute Limiter 2 @ VSTBuzz - Bedroom Producers Blog
