REAPER v7.19+dev0723
v7.19+dev0723 - July 23 2024
* Includes branch: internal buffering/antfx modernizations
* Includes branch: internal cleanups
* Includes feature branch: 128 track groups
* Includes feature branch: more combinations of peak display modes
* Includes feature branch: RGB profile tweak
+ Anticipative FX: more consistent performance with very low blocksizes
+ Automation: fix trimming of envelopes that contain multiple pooled items [t=293005]
+ Automation: reset latches (if not in Latch Preview) when moving edit cursor while stopped/paused [t=292915]
+ Custom menu editor: support for multi-selection/reordering/copy-paste
+ FX automation: fix issues with instant/toggle edits and latch preview mode [t=248330]
+ FX automation: reduce CPU overhead when automated parameters have no changes
+ Item ruler: improve display with very short media items
+ LV2: correctly handle relative URIs as (preset, e.g.) identifiers
+ LV2: disambiguate presets with duplicate names
+ LV2: support presets in external bundles
+ Razor edits: use default split-fade when copying [t=293002]
+ Recording: ignore loop points if recording is entirely outside the loop [t=293021]
+ Recording: improve item auto-punch behavior when new recording ends before the end of the original media item
+ Render: clicking render peaks display sets edit cursor in project
+ Render: display cursor at mouse position when mouse is within render peaks display
+ Render: display timeline/ruler below render peaks display
+ Render: fix render peaks display when user resizes render window to more than twice its original size
+ Render: fix render peaks display with very short renders
+ Render: improve render peaks display on retina
+ Ruler: avoid displauying unnecessary fractional seconds in media item, media explorer rulers
+ VST3: improve multiprocessing performance with large numbers of automated parameters/plug-ins
# Peaks display: auto-hide/resize controls based on peaks display
