NovoNotes have released Ambience Enhancer Lite, a completely FREE sound field plugin for macOS. This launch comes just before the full version of the plugin (Ambience Enhancer Standard) is released.
Ambience Enhancer is a unique plugin that isolates the aspects of your input that contribute to the ambiance it creates. It can edit the isolated elements while keeping the direct sound untouched. This makes the plugin ideal for making your sound fit a particular setting or mood. It has great potential in not only songs but music production in general.
Ambience Enhancer has three settings on its UI – Ambience Gain, Ambience Low Pass, and Ambience Delay. These settings may sound generic, but the valuable aspect is how it isolates only the ambient effect of the input and applies gain, low pass, and delay to it.
Aside from the ambient effect, nothing else in the sound is changed by Ambience Enhancer. No artificial effects or reverb is added to the signal. The plugin adds its three effects by decomposing the input, specifically editing the ambiance that it separates.
With Ambience Enhancer, you can make a recording taken in your home studio sound like it was done in a stadium or vice versa. You can also edit background music in any of your productions to match the video’s vibe or imagery. For example, a scene with open fields and a cool breeze can have music that feels like it was recorded there, with a lush ambiance.
Ambience Enhancer has a sleek, modern interface that looks gorgeous. It is all black with neon blue and purple markings. The sound levels are represented by concentric waves in white, the same color as the text. It looks aesthetic, and it’s effortless to navigate.
Ambience Enhancer Lite is the free version, but it has all the functionalities of the standard version, which is yet to release. The only limitation is you can use 2-channel audio (stereo).
Ambience Enhancer Standard will cost you $88 once released, which unlocks up to 24 channels. That’s perfect for multi-layered, multi-dimensional mixes where you need full control over your sound field.
So the lite version is the perfect starting point to decide if you need the full version, and for most, the stereo version would likely suffice.
The only gripe is that this is only available on macOS right now, with no Windows version just yet. It comes in the AU and VST3 formats, and an AAX version is coming soon. The download size is just 17 MB, and there’s no sign-up required – you just have to enter your email address to receive the download.
If you’re on macOS and you were looking for a free plugin to control and enhance your sound field, then you’re definitely in luck. Ambience Enhancer seems like a promising solution with an intuitive design, but alas, I’ll have to wait for a Windows version.
Ambience Enhancer Lite (VST3/AU plugin format for macOS)
资讯出处:Ambience Enhancer Lite Is A FREE Sound Field Plugin By NovoNotes - Bedroom Producers Blog
