v7.37+dev0430 - April 30 2025
* Includes feature branch: MIDI Poly Aftertouch chase/reset
* Includes feature branch: TCP toolbar
* Includes feature branch: pin tracks in TCP
* Includes feature branch: region editing preview display changes
* Includes feature branch: region/marker lanes
* Includes feature branch: MIDI item reconfiguration on effective timebase change
* Includes feature branch: phase alignment dialog
+ Big clock: hide customization indicator dots when mouse is not within the window
+ Click source: do not apply project or media item pitch shifting if click source setting to preserve pitch is enabled [t=300144]
+ Meters: improve dB scale positioning with certain themes when displaying gain reduction metering
+ Peaks: improve efficiency when using spectral peaks + LUFS graph, etc
+ Render: restore support for $namenumber wildcard
+ Toolbars: make tooltips positioned similar to track panel tooltips
# Peaks: fix spectral peaks disappearing on item edge resizes
# TCP toolbar: fix positioning of tooltip
# TCP toolbar: fix visibility with only pinned tracks visible
# Toolbar images: fix toolbar_add_insert image, default icon for TCP toolbar
