卧室制作人博客:Get 75% OFF MeldaProduction MTurboEQ @ VSTBuzz
VSTBuzz offers the MTurboEQ by MeldaProduction for just €37 (retail €149), which gives you a 75% discount. The offer is valid until March 18th, 2022.
MTurboEQ is a powerful equalizer plugin based on many great analog equalizers from the past, but it does not simulate them. Instead, it takes their strengths and eliminates all the unwanted noise and artifacts that the old-school analog systems may have had.
The featured equalizers are Motor Town Plus, Meve 7381, MSL E, MSL G, MPI 550, and several more. Every equalizer has a distinctively styled interface, and they have all the features of the model they were inspired by. Each model affects a different group of frequencies in different ways. You also get eight presets (from A to H) per equalizer.
The settings included in each equalizer are Input, Dry/Wet, Saturation, Analog, High-cut, and Low-cut filters, and variable gain control levels over specific frequency bands. You can also adjust the frequency bands individually.
The inclusion of all these equalizer types and presets with full functionality makes MTurboEQ an impressively versatile plugin. You can use the range of onboard presets to quickly find a sound that works for you, improving your workflow and reducing hassle. The different equalizers also help you keep your work sounding fresh with the use of different models for various projects.
Other features include 8-channel surround processing, MIDI controller compatibility with MIDI learn, unlimited sampling rate, safety limiter, Automatic Gain Compensation (AGC), and an online preset exchange that lets you share presets and download them from other users.
MTurboEQ is available on macOS and Windows in the VST, VST3, AU, and AAX formats. The UI is customizable and GPU-accelerated for peak performance. The plugin is well optimized and should work flawlessly even on an older PC.
If you buy the plugin, all updates are free for life, and there is no need to be online to activate/use the software. There’s also a 15-day demo version available to try before you decide to purchase.
Overall, the MTurboEQ plugin is versatile enough to work with just about any kind of music you’re interested in. It comes with Melda’s renowned audio processing quality, and the presets are handy starting points for any instrument track.
It’s also worth noting that WA Production Holy Bass House is currently free at VSTBuzz.
MTurboEQ (75% OFF @ VSTBuzz)
资讯出处:Get 75% OFF MeldaProduction MTurboEQ @ VSTBuzz - Bedroom Producers Blog
