v6.52rc1 - March 19 2022
* Includes feature branch: media explorer pitch detection
* Includes feature branch: improved peak building
+ Actions window: match UK spellings of various words
+ Automation items: when looping in latch mode, ensure there is an automation item to record into [t=263124]
+ Batch converter: add option to force single-threaded processing
+ Custom menus: fix menu after reset to default on macOS
+ FLAC/WavPack: improve lsb rounding for (17-23)/24-bit encodings
+ FLAC/WavPack: use identical rounding logic as .wav writing for 24-bit samples [t=263082]
+ FLAC: update to libflac 1.3.4
+ Includes feature branch: extremely minor tweaks to PCM rounding (-0.5 goes to 0 rather than -1)
+ JSFX: fix channel mapper/downmixer text alignment on non-retina macOS displays
+ MIDI editor: add actions, menu items to load/unload .ReaScale files
+ MIDI peaks: fix under-draw issue in continuous scrolling [twtr=1499242508328443904]
+ Media Explorer: rename .RPP-PROX when renaming .RPP files [t=263798]
+ Media explorer: add actions to adjust pitch by +/- 1 cent
+ Media explorer: add pitch knob option to adjust in cents
+ Media explorer: add preference to preview .RPP projects
+ Media explorer: add preference to suppress auto-render of proxy for previewing .RPP projects [t=260947]
+ Media explorer: add toolbar button to enable/disable pitch detection
+ Media explorer: fix context menu issues when opened via keystroke
+ Media explorer: optionally detect pitch during playback
+ Media explorer: shift+drag applies the previously selected pitch knob behavior (rather than always applying either continuous or semitone changes)
+ Media explorer: smoother transition when adjusting preview pitch via actions
+ Media explorer: support display feedback for actions to set pitch to X semitones
+ Notation editor: action to identify chords considers all notes playing, not just notes that start at the target time position [t=263540]
+ Notation editor: allow user-provided chords (from .ReaScale files) to override default chord names [p=2534376]
+ Notation editor: don’t show track/measure settings menu on left-click [t=238093]
+ Notation editor: treat click on measure start area as a click on the first beat of the measure, even if there is a key signature or time signature change
+ Peaks building: display file-level statistics
+ Peaks building: improve behavior when reordering tracks/items
+ Peaks building: improve multiprocessing use (4 or more cores when available)
+ Peaks building: optimize spectral peaks/spectrogram calculation
+ Project setting: add dropdown menu action to set project start measure to edit cursor position, rounded to nearest measure
+ Project settings: add dropdown menu to support setting/resetting project start offset and project start measure similarly
+ ReaFIR: add automatable parameter to adjust gain of EQ/threshold/noise profile curve
+ ReaPlugs: improve parameter names
+ Render: add action to re-display statistics from most recent render in web browser
+ Render: add option to display/not display RMS in render statistics
+ Render: add option to return to render setup window when render is finished [t=264054]
+ Render: enable “save settings” button when changing render tail setting
+ Render: ensure progress bar and stats are updated after rendering short regions
+ Render: gray out add-metadata button when “embed metadata” is unchecked
+ Render: greatly improve render speed when rendering many regions at once
+ Rendering: avoid extra work relating to updating status in dock on macOS
+ Text drawing: fix cropped glyphs for some fonts/italics combinations [t=262915]
+ Theming: in themes that overlap controls and track icons, draw track icons below controls
+ WavPack: fix incorrect truncation in 16-bit mode [t=261535]
+ Wildcards: support $channels wildcard in render, batch converter, and bounce
# Media explorer: improve pitch detection of low notes
# Media explorer: pitch detection displays root note only
# Media explorer: pitch detection processes only channel 1 for multichannel files
# Media explorer: support legacy actions to set pitch and reload media [p=2529032]
# Media explorer: update knob position when changing pitch shift via action
# Notation editor: “identify chords on editor grid” only notates chords when they change [p=2533547]
# Notation editor: prevent crash when loading .ReaScale file from action or main file menu
# Peaks building: rebuilding peaks for selected item no longer interrupts other items whose peaks are building
# Project settings: clarify meaning of dropdown action to set measure 1 to current edit cursor position
# Render: ensure statistics displayed in render output window are in the same order as browser view
# Windows: add legacy_filebrowse=1 .ini file option to use old file browsing open/save API for accessibility purposes
