GPU Audio released a free early-access version of FIR Convolver, a GPU-powered convolution reverb VST plugin for Windows.
FIR Convolver is the first plugin based on GPU Audio’s innovative GPU-based audio processing technology. The idea is to offload all DSP processing to a local or remote GPU, enabling instantly-rendered audio, zero-latency performance, and preventing DSP bottlenecks.
The plugin is free to download and use, but there are some limitations. The current version requires an Nvidia 10XX+ graphics card, Windows 10, and any of the following digital audio workstations:
- Bitwig Studio
- Ableton Studio 10/11
- Cakewalk
- MOTU Digital Performer
- PreSonus Studio One
- Reaper (recommended for early access)
- Magix Samplitude Pro X
- Magix Sequoia
- Cubase
If your computer meets all of these requirements, you should have access to an incredibly fast convolution reverb.
FIR Convolver is a simple convolution reverb, with a dry/wet knob and 10 built-in reverb impulse responses. It can load external impulse responses in WAV format, so you should be able to use your favorite IRs.
The headline feature, though, is GPU-based processing. Convolution reverbs are some of the most CPU-hungry plugins around, and offloading that to the GPU should significantly improve your DAWs’ performance.
Here is more info from GPU Audio:
“With GPU Audio, there is no added latency as a consequence of adding more instances so have fun and stress test your DAW! I was able to run 128 stereo instances within 1ms latency on Reaper, for example.
Please check the Read-Me as this is a test plugin, with purposeful limitations, and is currently only compatible on Windows PC with an NVIDIA discreet GPU. We are testing across most major DAWs Roadmap ahead includes, AU, macOS, AMD card support, and much more. GPU Audio is a full tech stack we designed to effectively parallelize audio processing across thousands of GPU cores, by offloading DSP from CPU to the GPU and returning back within 1ms latency.
The plugin is basically an open-benchmarking test for us as we prepare to launch an entire suite of products in 2 months We are also forming partnerships with great plugin makers to power up others’ future instruments and have lots of news coming.”
GPU Audio is working on expanding its compatibility with other platforms. AMD GPU support is expected to drop by the end of March, followed by a full beta plugin suite. Support for more DAWs and macOS-based systems is coming in 2024.
You can download the early-access version of FIR Convolver below. Please note that an Nvidia 10XX+ graphics card is required for the plugin to work. The current version of FIR Convolver will remain freeware.
FIR Convolver (22 MB download size, EXE installer, 64-bit VST3 plugin format for Windows 10)
- HZ Delay Is A FREE Echo/Reverb Effect By Higher Hz
- FREE Modern-Retro Drum Sample Pack By Reverb.com
资讯出处:GPU Audio Releases FREE FIR Convolver Early Access Plugin - Bedroom Producers Blog
