Sixth Sample releases Deelay, a FREE multifunctional delay plugin for macOS and Windows.
Deelay is a result of a collaboration between Sixth Sample and Integraudio. It is a versatile delay effect with several processing modes.
Right in the center of the GUI is the Delay Time knob (0-1000ms in Millisecond Mode). The Delay Time function has three more modes, Normal, Triplet, and Dotted, all of which sync to your project BPM. Either side of the Delay Time knob is Ping Pong and Mono switches.
The interface is relatively busy but straightforward and even comes with some help text when hovering over any control. It’s resizable too, which is always nice.
Going from left to right, we start with Diffusion Amount/Size controls that you can use to create interesting reverbs. Below those are basic filter controls, Low Cut and High Cut. If you look to the bottom right of the GUI, there’s an Fdb Filter button; when engaged, filtering is processed before the signal is fed back to the delay.
Under the filter settings are Tape and Distortion. Tape emulates the Wow/Flutter of an analog tape machine, introducing imperfections to the Delay Time. Distortion comes with various characters, from Saturation to Tube to Pixelated.
Next up is Duck, which sidechains the wet signal so things don’t get overly chaotic. It comes with Duck Attack/Release settings.
The right-hand side of the interface starts with Modulation Amount, which modulates the Delay Time, followed by Modulation Rate.
The remaining controls are Feedback, Spread, Dry, and Wet. There’s nothing too unusual, but Deelay does pack a decent amount into a free plugin while keeping everything neat and tidy.
If slightly quirky free delay plugins are your thing, check out HZ Delay (recently covered) or head to our FREE delay plugins article.
Other notable features include A/B testing and 100 factory presets.
Deelay is available in AU and VST3 formats for macOS (10.9 upwards) and Windows (8.1 upwards).
Please note that you’ll need to submit a valid email address to download the plugin.
- Sonosaurus Updates FREE PaulXStretch Time-Stretching VST Plugin
- Variety Of Sound Releases FREE FlavourMTC Passive Equalizer Plugin
资讯出处:Deelay Is A FREE Delay Plugin By Sixth Sample - Bedroom Producers Blog
