v6.63+dev0705 - July 5 2022
* Includes feature branch: render fade-in/fade-out
* Includes feature branch: media explorer loudness calculation
* Includes feature branch: render statistics improvements
* Includes feature branch: fixed lane play markers
+ GIF: fix memory leak when decoding files that have per-frame color maps
+ GIF: fix reduce memory use when decoding gif files with many frames
+ Help menu: sort documentation menu by filename [t=268485]
+ JSFX: set undo point after calling set_pinmapper_flags()
+ JSFX: support automating and undo for user mix volume sliders in channel mapper [t=266268]
+ Normalization: respect take channel mode when normalizing media items to target loudness [t=268290]
+ Project bay: add option to disable similar FX grouping in FX tab
+ Region manager: support selecting marker/region by name by typing in list view [t=268219]
+ Render: re-enable bounds dropdown if needed after loading render preset [t=268430]
+ Theme: improve rounding for knob stacks [p=2575187]
+ VST3: IContextInfoProvider3 support
+ VST3: fix return value for IContextInfoProvider::setContextInfoValue
+ VST: support IComponentHandler2::setDirty [t=268392]
