v6.64+dev0805 - August 5 2022
+ MIDI: fix incorrect ordering of certain notes in MIDI_GetRecentInputEvent
+ Media: sort insert-media file description/extension dropdown in alphabetical order
+ PCM/RAW files: support decoding 32 and 64-bit floating point audio
+ SD2/PCM/RAW: add button to source properties dialog to create/opening audio attributes file
# Grouping: mouse modifiers that ripple contents earlier or later affect grouped items even if edges don’t overlap
# MIDI retroactive record: add multiple takes if playback was looped
# MIDI: fix incorrect note ordering in retroactive record [p=2583519]
# MIDI: fix retroactive record length limit when stopped
# Media items: shrink selected item indicator when item height gets small
# Preferences: fix layout of Preference/Project/Media Item Defaults
# SD2: fix decoding stereo-to-mono
# Track grouping: improve grouping behavior when editing item edge
