v6.65+dev0813 - August 13 2022
* Includes feature branch: specify channel counts per-region in region render matrix
* Includes feature branch: media item fade editing changes
* Includes feature branch: .SD2/PCM/RAW file support
+ FX: fix UI glitches when showing offline FX in chain view (6.65 regression) [p=2586072]
+ Linux: improve behavior of listview clicks to listview images and manager fields
+ Linux: improve listview column alignment to match other platforms
+ Project settings: fix enabling/disabling pan law gain compensation in project settings advanced tab [p=2586016]
+ Render: fix applying render fades when project start time is negative and also applying brickwall limiter [t=269619]
+ Render: fix filename auto-increment matching non-numeric characters [t=269586]
+ Track grouping manager: fix checkbox appearance with dark themes on Windows
+ Track manager: add option to show/hide/group child tracks when showing/hiding/grouping folder track
+ Track/Region/Group managers: support resetting custom colors to default
# Track grouping: display track media/razor edit grouping indicators for automatic groups even if there are no other track groups defined [p=2586061]
# Track grouping: razor edits respect automatic track grouping
# Track manager: fix persistence of visible/hidden column state [p=2585978]
