卧室制作人博客:DIONYSUS Acoustic Piano Is FREE @ Audio Plugin Deals
Audio Plugin Deals launches an exclusive freebie deal on DIONYSUS Acoustic Piano ($99.99 value), an acoustic grand piano sound library by Muze.
DIONYSUS Acoustic Piano is a massive 24.81 GB piano sound library for Native Instruments Kontakt. The instrument is based on 12,982 individual samples. It requires the full version of Kontakt and will only work for fifteen minutes in the free Kontakt Player plugin.\
The library features 55 sampled sound sources. These include a variety of keys, bells, electric pianos, mallets, and guitars. The star of the show, however, is the deeply sampled Bechstein D Grand piano.
The user can mix and match different sources to create new and unique instrument combinations. Use the layering engine to morph and blend multiple sound sources, then adjust the global envelope and FX settings to polish the sound on the output.
To simplify the layering process, the instrument also features an XY pad which lets you morph between different sounds without adjusting the faders manually.
DIONYSUS Acoustic Piano comes with a 10-channel mixer that lets you apply various effects and tonal adjustments to each sound source. There are twelve built-in effects in total, including compression, delay, reverb, EQ, modulation, and more.
Typically priced at $99, the DIONYSUS Acoustic Piano is available as a free download for a limited time only exclusively via Audio Plugin Deals. The free download offer ends on June 3rd, 2021.
Hear the instrument in action in the demo video embedded below.
To claim your free DIONYSUS Acoustic Piano, visit the product page on APD’s website, add it to your shopping cart, and complete the checkout process. A valid email address is required.
Also, keep in mind that you will need the full version of NI Kontakt (v5.8 or later) to run DIONYSUS Acoustic Piano in your DAW.
Audio Plugin Deals is running several sales at the moment, including special offers on PREPARATO Piano by Xperimenta Project and ARPOLOGY Cinematic Dimensions by Sample Logic.
DIONYSUS Acoustic Piano (FREE until June 3rd, requires Native Instruments Kontakt 5.8 or later)
资讯出处:DIONYSUS Acoustic Piano Is FREE @ Audio Plugin Deals - Bedroom Producers Blog
