v6.29+dev0524 - May 24 2021
* Includes feature branch: render normalization
* Includes feature branch: EEL2 x86_64/SSE
* Includes feature branch: VST3 bridging
+ Actions: cycle folder collapsed state will not modify state of selected non-folder tracks
+ Render: allow rendering to primary/secondary of the same type (e.g. wav 16-bit and 24-bit, $bitdepth recommended in wildcard)
+ Render: apply dither/noise shaping to secondary render format if enabled and format supports
+ Render: disable audio normalizing for video renders
+ Render: display peak, rms, and overs when normalizing
+ Render: improve render speed when normalizing
+ Render: show first actual file used when rendering to multiple files that are autodisambiguated
+ Super8: allow controlling loop length via automatable parameter
+ Super8: fix off-by-one-sample error in first-pass recording
+ Super8: per-channel length-division setting
# Render: display render meters post-normalization for greater-than-mono tracks
# Render: if normalization would require adding more than 60dB, don't normalize
# super8: fix sync mode reset bug added with hidden parameter
