UJAM releases Usynth DRIVE, a streamlined freeware virtual synthesizer for house music production.
Usynth DRIVE is a virtual instrument tailor-made for electronic music producers. More precisely, UJAM describes it as a “turbo boost for electronica” and a virtual instrument suitable for use in house music.
Similar to the other plugins in the Usynth range, Usynth DRIVE is powered by a versatile synthesis engine. In fact, it uses two layers per sound and combines multiple synthesis algorithms, including subtractive, FM, wavetable, and multi-sample synthesis. It also features a multi-mode filter, a 12×12 modulation matrix, five-stage envelopes, and other advanced modulation features.
Despite the complex synthesis engine buried underneath the surface, the GUI shows only a handful of controls. The idea behind this approach is to provide the user with a selection of ready-to-use sounds without having to worry about synth programming.
On the other hand, Usynth DRIVE offers a set of customization controls so that each patch can be modified to fit a particular project. The interface is organized into three main sections: Sequencer, Synthesizer, and Finisher. Each section can be bypassed, randomized, or tweaked manually.
The Sequencer section helps you sequence the loaded sound by adjusting the swing, note length, tempo, and similar parameters. The Synthesizer section is where you’ll modify the timbre and the internal modulation. The Finisher module features a set of built-in effects that will add depth and movement to the loaded preset.
The plugin also features a handy Surprise feature that lets you create a fully randomized preset. The surprise can be “small” or “big,” which basically determines how much the randomized preset will deviate from the current setting.
A virtual keyboard is present at the very bottom of the interface, along with the pitch bend, modulation wheel, and MIDI settings.
Check out the demo video embedded below to hear Usynth DRIVE.
According to UJAM, the new Usynth DRIVE synthesizer is completely free to use with no strings attached. They say it’s a “present to friends old and new.” Being that the other Usynth plugins cost $79 each, this is quite a generous freebie from UJAM.
Even if you don’t produce house music, Usynth DRIVE is worth considering as a source of modern electronic music sounds. It’s also a nice way to check out UJAM’s style of creating plugins. They value hands-on playability above tweakability, and producers who are working on tight deadlines will certainly appreciate that approach.
Usynth DRIVE is available in VST, AU, and AAX plugin formats for compatible digital audio workstations on Windows and macOS.
- SynthMaster One iOS App Is FREE For A Limited Time
- RepliCat Releases FREE GreenWave Virtual Synthesizer
资讯出处:Usynth DRIVE Is A New FREE Synthesizer By UJAM - Bedroom Producers Blog
