v6.73+dev0106 - January 6 2023
+ Audio Units: respond to kAudioUnitProperty_ParameterList to update parameter list at plug-in request
+ Audio Units: when bridged detect tail time changes
+ FX: improve behavior when loading projects and audio device asynchronously changes samplerate
+ LV2: do not unload plug-in bundles on macOS [t=274448]
+ LV2: fix potential crash on macOS UI destruction [t=274448]
+ ReaScript: add GetInputActivityLevel()
+ Screensets: overhaul MIDI editor behavior [t=273783]
+ VST: re-map automation by parameter ID if parameters change due to restartComponent
# JSFX: support log/sqr scaling for parameters with inverted ranges
